OPC Server PLC
Hallo,
I am doing right now the tutorial from NI " Connect LabVIEW to Any PLC Using OPC". And the first capital was everything richt, "View Existing PLC Tags with NI OPC Servers 2012".
But in the second capital "Connect LabVIEW to OPC Tags by Creating an I/O Server" I can't get the picture as the 4. step "Select OPC Client in the Create New I/O Server Window and click Continue. ".
The problem is, there is no option for "National Instruments.NIOPCServers.V5" to choose by me. How can I get the pic as the tutorial?? Why I can't get the "configure OPC Client I/O setup" menu??
My system:
LV 2012,  Win7,
Does somebody know the problem??
Thanks a lot!
Cabio
Message 1 of 10
(8,013 Views)
HELP
Message 2 of 10
(7,945 Views)
NO one knows about it?
Message 3 of 10
(7,924 Views)
Do you see the OPC Server in the distributed system manager?
Is your NI OPC Server running? There should be an icon in the tray, where you can configure it.
Best regards
Johannes
Message 4 of 10
(7,913 Views)
There is no OPC Server in mein DSMSmiley Indifferent
But Why?????
Message 5 of 10
(7,910 Views)
Basically that means, your OPC server is either not installed or not running. Please open the OPC Server Configuration Tool. In your taskbar there should be a symbol OPC UA Server. Right click on it and choose start runtime service.You can also use that tool to configure endpoints trusted clients etc.
Also note the OPC Quick client, which basically is the same as the DSM. In here you should also be able to add the NI OPC Server.
Message 6 of 10
(7,881 Views)
But I think my OPC Server is running, the tool OPC Quick Client can connect to server "National Instruments.NIOPCServers.V5", it is also showed in the Pic.
And I have fund a VI "C:\Program Files (x86)\National Instruments\LabVIEW 2011\vi.lib\variable\tagger\opcClient\GetOPCServerList.vi", this VI can find the "National Instruments.NIOPCServers.V5". But NI-DSM cant find it.
I am confused~~~Smiley Frustrated
Message 7 of 10
(7,874 Views)
Ok, which way are you connecting to LabVIEW? Are you using ni "datalogging and supervisory control" Modul, or are you using datasocket? You only can connect serverIO via DSC Modul. I just removed it on my pc, and got the same feature as you have.
Message 8 of 10
(7,849 Views)
Yeah, Datalogging and Supervisory Control module should be installed if you want to use it as IO server.
Message 9 of 10
(7,838 Views)
I have installed the DSC module in my Computer, but never used.
So I will reinstall this module, and hope, it works.
Message 10 of 10
(7,814 Views)
