One FPGA Reference, 2 Paralle FIFO Running, How to Close Reference?
The FIFO are being directed from a single FPGA reference. If you see to the most right, I have 2 close reference which when I press stop button, it gives me error dialog. What's the correct way to close both FIFO?
(3,064 Views)
You aren't closing the FIFOs.  You are closing the reference to the FPGA.  You only need to close the reference once.  So get rid of one of your Close FPGA Reference nodes.
GCentral
(3,057 Views)
So I dont have to connect the second FIFO into a close reference?
(3,049 Views)
Accepted by topic author augustg
That is correct.  The reason is because they are both the same reference.
GCentral
(3,045 Views)
ok, thanks~
(3,041 Views)
