One button with 3 or more cases
where should I connect the conditional terminal in the while loop?
Message 11 of 19
(1,972 Views)
You'll need a STOP button that will stop the VI completely.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 12 of 19
(1,967 Views)
I couldn't make the tunneling into a last value tunnel. Why is that?
Message 13 of 19
(1,933 Views)
I removed the quotient-remainder function because when we set the constant to 3 and the elements are incremented (so we have 1,2,3,4), the resulting remainder would be 1,2,0,1 - which only shows the sine and square waveforms.
The only problem is the looping in which, after I click the boolean button 4 times, I would have to click it once more so that the loop would repeat again. This would be satisfactory if I run the VI continuously.
But anyway, thank you for the ideas. I wouldn't be able to generate this program without your guidance ^_^ although I know there are still some flaws.
Message 14 of 19
(1,927 Views)
Hi geneclaude,
So why don't you set the quotient to 4 when you need the values 0,1,2,3 as remainder? Quite simple math…
Message 15 of 19
(1,915 Views)
the low down and dirty....ex. waveforms remainders: (sine#0,cosine#1,sawtooth#2,square wave#3), sorry about added cosine?  Smiley Surprised
* edited....
like gerd had said...."So why don't you set the quotient to 4 when you need the values 0,1,2,3 as remainder? Quite simple math…"   Smiley Wink
Message 16 of 19
(1,913 Views)
@GerdW wrote:
Hi geneclaude,
Or, as I originally suggested DO NOT use a constant.  Create a property node for the Waveforms control read Number of items.
Now when you add or remove items the modulo math doesn't breakSmiley Wink
Message 17 of 19
(1,875 Views)
@JÞB wrote:
@GerdW wrote:
Hi geneclaude,
aaaaaaah, that is what you meant.....maintainable? or scalable? I get confused which term....   Smiley Tongue
Message 18 of 19
(1,871 Views)
There is enough interaction between the two that deliniation is usually not necessary.  Maintainable code is scaleable and vice versa.
For instance:  If you stick that code in a proper design pattern (and what you have is close[ish) the code practically reads itself and changes are easy.
Tease VIA snip:  Vi attached
Message 19 of 19
(1,850 Views)
