Open/Close state switch
I'm using mech. switch and I want to stop my VI once it's triggered. I can also put this application to a sequence stracture and will move to the next frame till the switch is triggered. Do I need to do this in digital or analog? Any help would be appreciated.
Thanks in advanced!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(3,372 Views)
While you could do this in analog, you are better off using a digital input.  Generally a +5V signal on the input means true, and a 0V input means false.
You'll have to provide details on what type of DAQ hardware you're using if you need more help.
(3,356 Views)
I have the following hardware:
PCI-6024E
SCXI-1000 / SCXI-1180 / SCXI-1302
Thanks!
______________
KowdTek
LabVIEW 2009
(3,339 Views)
Hi FlipTek,
A good place to start will be checking out the examples in LabVIEW. You can get to them by navigating in LabVIEW to the Help menu » Find Examples. This will bring up the Example Finder. A few good examples to look at for your application will be the digital measurement examples. They can be found when browsing by task under Hardware Input and Output » DAQmx » Digital Measurements.
Here is an example I modified which will stop a loop when the value changes from a high state to a low state.
I hope this helps!
Kent
Applications Engineer
Message Edited by tnek on 03-11-2008 06:07 PM
(3,310 Views)
