Open VI Reference Function and a RUN VI RUN VI Method Causes Error 1000 with version 2014
@aputman wrote:
No, that is not the subpanel.  If you look at the first VI you posted (RunTestinSubpanel), that VI is called from somewhere and a reference to the subpanel is passed to it.  That is most likely where the subpanel can be found.
attached is the VI that calls it.
This is a very involved set of VIs
thanks
Message 31 of 44
(3,752 Views)
I am late to the game ... excuse if already covered...
A property node >>> Execution >>> state will tell what state the target VI is in. Add an indicator and see if there is a difference between the development and run time.
Ben
Message 32 of 44
(3,747 Views)
I'm going to say that this is the offending piece of code.  Creating the static reference to the test vi reserves it for running, causing you to get the error 1000 when you try to open the reference again and run it.  Why it works in 8.6 and not 14, I can't say.
aputman
Message 33 of 44
(3,742 Views)
I am not sure.
I have often used static reference to ensure that dynamically loaded VIs are included in a build without the manual work of including them explicitly in the build. They also let me reference the target VIs by just using the name and not having to figure out what the correct file spec inside the exe should be.
It really seems that the target VI in this discussion is either broken, already running, or reserve to run being part of another already running VI.
Just my 2 cents,
Ben
Message 34 of 44
(3,732 Views)
Ben
Thanks for the idea Ben.
Not sure how to incorporate that though...
Message 35 of 44
(3,725 Views)
Ben
Mark the VI that does the launching as "show FP when called" and make sure the indicator of the state is visible.
Ben
Message 36 of 44
(3,722 Views)
@Ben wrote:
I am not sure.
Just my 2 cents,
Ben
Right.  My comment is only true for strictly typed references, which these are not.
aputman
Message 37 of 44
(3,717 Views)
Accepted by robojeff
The false case of that same bit of code has the VI being called like a normal subVI.  It looks like that was an attempt to load the test into memory as well but is not being used.  Doesn't this reserve the VI for execution?  I would assume in an EXE that this code would be removed completely since it can never be called anyways but in the IDE environment, that wouldn't be the case, correct?
If you just delete these VI's from this case, see if that fixes the issue.
aputman
Message 38 of 44
(3,713 Views)
That was it.
I removed those and now it runs.
I added them back and I get the error 1000
Thank you everyone for helping to solve the problem...
Message 39 of 44
(3,707 Views)
After some thought, this might not be a LabVIEW 2014/ 2015 issue at all...
It might be a Windows 10 issue and how and what it allows LabVIEW to execute out of memory...
Message 40 of 44
(3,696 Views)
