Open datasocket connection error 42
Yes wiebe@CARYA, for me, it sounded like DCOM in OPC but I think Pataclaque is not using an OPC server.
As you may see in this White Paper http://www.ni.com/white-paper/12402/en/; the datasocket uses TCP port 3015 (for DSTP) and it should be opened in the firewall of both server and client.
If this is already so, then, I would try to use an example of LabVIEW. Are you using an example as Simple DataSocket.lvproj that is in the LabVIEW example finder
Message 11 of 24
(3,970 Views)
Yes I did.
Computer A:  I had to re-installed Windows 8 and LabVIEW 2012.
Computer B: It stays the same and run the executable that we are talking about.  It tries to "Open Datasocket Connection" to a shared variable located on the Computer A.
Michel
Message 12 of 24
(3,970 Views)
No, I'm using the same code that was working like a charm prior the re-installation of Windows 8 on Computer A.
Message 13 of 24
(3,964 Views)
@eaguero wrote:
Yes wiebe@CARYA, for me, it sounded like DCOM in OPC but I think @Pataclaque is not using an OPC server.
But the application works when run in LabVIEW. It's only the executable of the application that does not work.
On the remote computer, it's a shared variable. So he's trying to read a shared variable (OPC) with datasocket. It seems to be the DCOM interface of the remote computer blocks the executable, but not LabVIEW.
Message 14 of 24
(3,959 Views)
Yes, this is currently the situation I have.  To make it clear, prior the re-installation of Windows LabVIEW and the executable was working fine.
Message 15 of 24
(3,954 Views)
If you have time, try a simple VI that access the shared variable as:
shared variable,
with Open shared Variable funciton,
and datasocket.
When it works, try to make an executable. I'm guessing the Open Shared Variable gives a lot less problems then the OpenDatasocket.
I'm off now, good luck.
Message 16 of 24
(3,951 Views)
Ok, I will try that.
Michel
Message 17 of 24
(3,947 Views)
Accepted by Pataclaque
Hello everyone,
I checked back my antivirus "Norton 360" on computer B, which has always run perfectly, by launching it from the tray icon.  I had an error related to Norton software, so I decided to uninstall completely from the computer B.  Guest what, everything is now running as before.
Michel
Message 18 of 24
(3,937 Views)
Those are great news Patacle!
Message 19 of 24
(3,924 Views)
I have a problem about DataSocket Read Function . I want to read some data from OPC server. I read data and its value 100  as seen in picture dOPCexplorer . But when I give a start Labview .exe as seen Santral Veri Kayıt.vi, I get error 42 about DataSocket Read. Can anyone help me when solving this problem?
Message 20 of 24
(3,894 Views)
