Open vi reference
can anybody tell me why LabVIEW doesn't finish execute of the "open vi reference" function when I'm interacting with e.g. context menu? I have attached a picture for more understanding.
Thomas
(4,308 Views)
Whats the value to the options you are passing?
attach code instead of Image.
(4,297 Views)
No, I can't tell you what's wrong because you attached a picture instead of the actual code.
(4,296 Views)
Accepted by ThomasKeyser
"Root Loop"
See here.
in order to keep things straight avoid race conditions and dogs and cats living together, there are some operations that take place in what it called "root Loop" durring which everything else is blocked. See the link I provided and then the link sin that thread.
Ben
(4,254 Views)
