Opening two submenus parallely
Ranjeet,
i see your problem.
Honestly, the way you design the user experience is....not recommended. I recommend you to have as few windows as possible.
That means, that the options in the runtime menu do not open individual windows, but work inside the main application window.
Two possible ways are easy to implement:
a) Use a tab control to include each window as an integrated view in the main front panel. The issue here is that separating functionality as subvi might get "complicated" and you only see one function at a time (even though you can "swap" during execution!).
b) Use two or more Subpanel controls and insert the VI(s) there
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 21 of 23
(880 Views)
Actually all this comes indside one VI opens when user enter appropriate user name and password.
Is calling each VI using asynchronous is OK?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 22 of 23
(875 Views)
Accepted by Ranjeet_Singh
If I change the way I call the subVIs then this problem is solved.
Here is the attach VIs(Take a look at testing and report). Let me know if any other way we can implement this.
--Ranjeet
Message 23 of 23
(850 Views)
