Output Smooth Sinusoid to DAQ
That's why it's important to run the example I mentioned. The DAQ Assistant hides everything. You can however, right click on it and select "Generate DAQmx Code'. But try the example first and the test panel in MAX.
Message 11 of 12
(450 Views)
When I run the example it generates a very nice sinusoid without any problems.  I have already run the test panel in MAX several times.  I have also just tried modifing the example to include my waveform and it does seem to be working, but I will need to adjust a few more things and try it with my pump before I can be sure everything is working fine.  Thanks for the help.
Message 12 of 12
(442 Views)
