PCI-6251
hi there ,
I need to drive a Soleniod valve by labview with these specification (solenoid valve)
I am using a PCI-6251+SCC 68 connector block. as the valve is a big one I think I need a external power supply as the card internal voltage is not able to operate the valve.
my only question is how can I wire the valve to the connector block. I am also using a relay switch on the valve.
regards
Hesam
(3,151 Views)
Hi Hesam,
I'm one of the Applications Engineers working at National Instruments, and with regards to your query I can point you to the relevant, comprehensive information that will help you how to configure your system:
SCC Quick Start Guide
https://www.ni.com/docs/en-US/bundle/373743d/resource/373743d.pdf
SCC User Guide
https://www.ni.com/docs/en-US/bundle/scc-68-seri/resource/374748b.pdf
Ben
(3,098 Views)
