PCI-6528 question
Hi, Guys:
I have almost zero experience with Digital I/O - is it possible to do pulse width modulation with a PCI-6528?
Sorry it's dumb question, but like I said, I have about zero experience doing Digital I/O.
Bill
CLD
(Mid-Level minion.)
(2,993 Views)
It doesn't need to be precise timing, do you think maybe I can do a brute force software-timed solution?  I was hoping for a more elegant solution?
Bill
CLD
(Mid-Level minion.)
(2,988 Views)
Accepted by billko
I've done it using counters... with DO its possible, consider using 'regeneration mode' and 'dynamically updating user buffer data' should be selected.
For analog output, 'dynamically updating user buffer data' is explained here. For 'regeneration mode' refer this. See if you can club these together.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,964 Views)
I will check these links that you have so thoughtfully provided.  Thanks for being so patient!
Bill
CLD
(Mid-Level minion.)
(2,949 Views)
I'm thinking this is gonna do it for me!!!
Thanks, mod - with kudos and a solution!
Bill
CLD
(Mid-Level minion.)
(2,946 Views)
