PCIe 8361 PCI-to-PCI bridge does not show up.
I replaced an old PCIe 8361 card, but the “PCI-to-PCI bridge” does not appear in device manager.
Is it because the chassis is not connected?
I don't have a chassis on hand.
I know I can connect the chassis and try it out, but due to circumstances I would like to make a decision without the chassis.
(780 Views)
Hi fagoon,
There's a version of the PCIe-8361 that doesn't have a bridge on it, but it is/was only bundled in a few select kits. Unless you have this version there should be at least one PCI-to-PCI bridge in device manager. Is this the same PC that the old card was in? What's the part number of the new one?
- Robert
(759 Views)
Hi Robert,
Thanks for the reply.
The old one is ASSY 199042A-01L and the new one is 195317C-01.
I tried it on the same PC.
(736 Views)
Accepted by fagoon
Hi fagoon,
The new one is the version that won't show up in device manager (regardless of whether a chassis is attached). You won't be able to tell whether it works without connecting a chassis.
- Robert
(723 Views)
Thank you so much for the very useful information.
much appreciated!
(706 Views)
