PDA EMAIL ATTACHMENT VI - NO RESPONSE
SMTP Email Send Message (Small).vi works great on my Samsung SCH-i760 Windows Mobile 6.0 Pocket PC smartphone.
SMTP Email Send Multiple Attachments - PDA.vi will not complete on my smartphone.
It appears to timeout, then sometimes there is no error, sometimes error code 6 and 10051.
Suspect that input to attachment input on vi is the problem.
But do not know how to to isolate this problem better.
(5,435 Views)
Hi Markfrank:
Can you try SMTP Send Single attachment in a loop & see if you get the same error?
Robert
(5,409 Views)
Thank you.
It turns out, the path was the main issue.
After changing the path from "\my documents\sensordata3.txt" to "my documents\sensordata3.txt" it partially worked.
Meaning it sends the attachment just fine.
However, if a "sent from email address" is included with vi, then it do longer sends any email.
Also, if the attachment is 140kbytes, it gets truncated to 20kbytes, and is unusable.
(4,925 Views)
