Showing results forĀ
Search instead forĀ
Did you mean:Ā
PSK demodulation
I want to demodulate a pulsed PSK signal,
the signal is build up like this:
Frequency: 406,028 MHz -> downconverted to 6,028 Mhz
Total pulse time: 520 ms
pure carrier: 160 ms
Modulated part: 360 mS (offcourse)
Modulation: BPSK at a baud rate of 400 SPS, the phase begins at 0 and than switches between 1.1 and -1.1 Rad.
What I have done so far is downconvert the signal to approximatly 6 MHz and than save a selection of the pulses to one file with the HWS storage VI's (saving with it a lot of info (gain and offset, sampling rate) (5 times oversampling)).
Than I made a routine that can read one pulse and chunk it up to stream it to an other program part where I want to process it...
Now is My question, does anybody allready written a good demod program for BPSK, otherwise where can I find a good description for this. I do have the modulation toolkit...
Best regards
Joost van Heijenoort
Engineer at Ursaminor space and navigation.
Message 1 of 8
(7,441 Views)
Dear Joost,
The Modulation ToolKit includes two example that shows how to do PSK Demodulation. These example includes BPSK.
You can find the Example in the Example Finder under: Toolkits and Modules -> Modulation -> Digitizer -> MT niScope PSK Demod.vi or MT niScope PSK demod (5122).vi
Hope this helps
Karsten
Message 2 of 8
(7,396 Views)
Is There somewhere a good discription on how the Tools in the modulation kit work....
This because i have trouble making a program that can demodulate the upper signal. Frankly at this moment i am not sure what i am doing....
regards
Joost
Message 3 of 8
(7,356 Views)
Hi Joost,
Please check the help-file.
 'This because i have trouble making a program that can demodulate the upper signal'.
What would you like to know?
Bas van Dijke
AE, Netherlands
Message 4 of 8
(7,347 Views)
Hee Bas,
Do you have an direct email adres?
gr
Joost
Message 5 of 8
(7,345 Views)
Joost,
My emailadress is: bas.van.dijke@ni.com
Bas
Message 6 of 8
(7,342 Views)
hello,
i am working on LV PCI 5640 R, i am not able to do  Modualtion of PSK(BPSK etc..)signal in the FPGA vi. please help me how to create the FPGA part.
thanks.
Message 7 of 8
(7,036 Views)
Hi IF-RIO,
Please post your question on the forum linked below.
Bas van Dijke
AE, Netherlands
Message 8 of 8
(6,951 Views)
