PXI 6608 80 MHz timebase
I have a PXI system with a 6608 timer device in slot 2 and a 5122 digitizer in slot 3.  I know that the 6608 has an internal 80 MHz timebase, and I would like to use this timebase as a clock source for the 5122 using LabVIEW.  I would prefer to route the timebase internally through the PXI backplane or a RTSI line, but would accept routing the timebase to something like PFI 0 and wiring it externally to the digitizer CLK IN.  I have not been able to learn how to route the timer's 80 MHz timebase to another line that the digitizer can use for a clock source, and I have not learned how to use any digitizer external clock source but CLK IN and PXI Star.  Any help would be appreciated in learning any of these things.
(2,561 Views)
Please see this post.
Natasa
(2,545 Views)
