I have a PXI system with a 6608 timer device in slot 2 and a 5122 digitizer in slot 3.  I know that the 6608 has an internal 80 MHz timebase, and I would like to use this timebase as a clock source for the 5122 using LabVIEW.  I would prefer to route the timebase internally through the PXI backplane or a RTSI line, but would accept routing the timebase to something like PFI 0 and wiring it externally to the digitizer CLK IN.  I have not been able to learn how to route the timer's 80 MHz timebase to another line that the digitizer can use for a clock source, and I have not learned how to use any digitizer external clock source but CLK IN and PXI Star.  Any help would be appreciated in learning any of these things.
