Package DAQMx drivers with my Labview application Installer build?
I am running Labview 7.1.1. How do I package DAQMx drivers within an Installer and subsequant .BLD file? I have VI application which uses the DAQMx drivers and I want to be able to create an executable and installer that will install the DAQMx drivers when I have a user install the application on their machine. I have already built the executable but cannot figure out how to include the driver install within the application installation.
Message Edited by aaronb on 11-18-2009 01:05 PM
(3,673 Views)
Anyone?....Bueller
(3,641 Views)
Accepted by aaronb
Good Afternoon aaronb,
Have you seen the section titled, "LabVIEW 7.1 and earlier" in the following KnowledgeBase article.
How Can I Include Additional Installers with My LabVIEW Applications' Installer?
As a note, creating and distributing applications became significantly easier in later versions of LabVIEW.  Have you considered upgrading?   LabVIEW 2009 just came out in August 2009.
(3,632 Views)
I have LV2009 already installed but am having problems with it.
(3,616 Views)
