Packing and unpacking bits
Hi Billko,
It is some thing similar but more in line with my previous post.
Message 11 of 22
(2,800 Views)
Accepted by SolPS
@SolPS wrote:
I can only provide a description as shown below
Byte     no of Bits     Data       Value         Data Type
 0             2              Data1      0-2            Enumeration
Looks like we cross-posted.  That's perfect.  So it looks like you're sending one byte.  The data itself is a two bit number 0-2, or 00, 01, 10 binary.
Oh, Data1 is an 8-bit enum.  Enum prevents you from entering invalid data.  Guess it would've been helpful if I took the screenie after I ran it.  Sorry.
Also, some people like to use Boolean arrays; I like to use clusters and convert them into an array so there is no way you can end up with too many/not enough elements.
Bill
CLD
(Mid-Level minion.)
Message 12 of 22
(2,796 Views)
You won't be able to represent your enum with less than 8 bits.  You'll just have to live with it and make it impossible for the user to select invalid values like how I did in the snippet.
Bill
CLD
(Mid-Level minion.)
Message 13 of 22
(2,790 Views)
Hi Bilko,
I'm sending a combination of data types in one byte.  More like the description below.
                1              Data2       1/0                     1bit Boolean
                1              Data3       1/0                     1bit Boolean
                1              Data4       1/0                     1bit Boolean
                3              Data5        0-2                    Enumeration
Message 14 of 22
(2,785 Views)
You should be able to expand my example to include your revised format.  🙂
Bill
CLD
(Mid-Level minion.)
Message 15 of 22
(2,783 Views)
Ok. I will give it a try. Thanks for your replies.
Message 16 of 22
(2,779 Views)
@SolPS wrote:
Hi Bilko,
That last value (3bits) can be from 0..7, of course, but you don't really need to use all bits.
It is extremely wasteful to explicitly code all these shifts and masks, because there are so many places for bugs to hide. Use a FOR loop and you are all set. All you need to know is the number of bits per field. Right?
Here's a simple draft:
Of course you don't really save anything useful. Sending one byte vs. five bytes over UDP costs you a packet either way and the size difference in payload is negligible compared to the entire packet with headers, etc. You could just cast of flatten the cluster to a string and back.
Message 17 of 22
(2,771 Views)
Hi Altenbach,
I need to send the entire byte. The last 3 bits will be used in padding the data.
Thanks.
Message 18 of 22
(2,766 Views)
@SolPS wrote:
Hi Altenbach,
Since the minimum size is on byte, there is no padding. You re simply ignoring these bits. 😉
Message 19 of 22
(2,763 Views)
@altenbach wrote:
@SolPS wrote:
Hi Bilko,
I don't think that is correct.  It seems to me that the formatting of the data has already been set.  It is one byte, consisting of: one number represented by two bits, three Booleans, then another number represented by three bits.  I think there is no room for interpretation here.
Bill
CLD
(Mid-Level minion.)
Message 20 of 22
(2,748 Views)
