Parallel Port Comms on a 64-bit Windows 10 machine
I am trying to communicate with a legacy instrument that uses the parallel port. I know that this is not easily done on a 64-bit OS. I searched google and the forums and found some inkling of people who may have succeeded in achieving this.
So, is there any way to use Labview and communicate with a parallel port on a Windows 10 64-bit OS?
Thanks!
A
Message 1 of 10
(5,265 Views)
Are you trying to achieve GPIB communication with an instrument. If so it should be possible with the drivers provided by the Manufacturer or NI.
Thanks & Regards,
Bharath Kumar
GCentral
Message 2 of 10
(5,214 Views)
Hi Alex,
use an USB-to-parallel port converter. They are available similar to USB-to-serial converters…
Message 3 of 10
(5,204 Views)
It really depends how the software uses the parallel port. If it simply uses the serial port (yes Microsoft treats both ports as serial port, one is bit serial and the other is byte serial) Windows API or NI-VISA then there should be no problem, or rather you might still have a problem as parallel ports are nowadays pretty uncommon on computers. But here the suggestion from Gerd with an USB converter should work.
If the application however uses the parallel port to bit bang data through direct register calls then yes that is gonna be difficult.
Rolf Kalbermatter  My Blog
Message 4 of 10
(5,184 Views)
The software sends an 8 bit integer into the parallel port and flips all of the values at once. I think this means it is byte serial. I would like to be able to flip all 8 data pins of the parallel port at the same time, with ~5 ms precision. I believe this signal goes into a multiplexer which then addresses a relay corresponding to the 8 bit integer.  Does that make sense?
Message 5 of 10
(5,145 Views)
It also doesn’t need to be a parallel port I suppose, I just need some form of parallel communication generated by labview with fast switching speeds.
Message 6 of 10
(5,144 Views)
A digital output module?
Message 7 of 10
(5,135 Views)
In order to accommodate the ~5ms requirement, I would say it would need to be either a High Speed DIO or an FPGA board.  Personally, I would be more inclined to go with the FPGA board as it gives me A LOT more control.  cRIO or an sbRIO would be another option (thinking myRIO at the moment).  Or you could even go with an Arduino board and give it instructions through the serial port (thinking LINX or a custom sketch and application).  There are plenty of ways to do this.
GCentral
Message 8 of 10
(5,109 Views)
Where does that 5ms precision come from? Why and how? If you want to create pulses on the digital port with such a precision then it's going to be problematic, if you want to make sure that all 8 lines change within that time then there is no poblem. So what sort of signal do you need? You mentioned 8 digital lines that all need to be changed at the same time. Why is that? If they all change at the same time you could just as well use a single digital output to control all the 8 channels in parallel.
Message 9 of 10
(5,087 Views)
What is wrong with a USB 6501 or heck even a NI 6008,
Just drive the 8 DIO with DAQmx!
Message 10 of 10
(5,072 Views)
