Parallel while loops
Hi
I'm currently studying Mechatronics and I am pretty new to Labview.
So sorry if this sounds very basic.
I have project to where I have to detect Temperture and Humidity concurrently, and adjust them.
In my VI the Temperture While loop is working as hoped, but the Humidity While loop wont even start/Initialize. Any ideas to help. Any help would be greatly appreciated.
Thanks in advance.
(3,113 Views)
I'm running LV2019 and can't open your VI, could you do a screenshot for me, please?
(3,106 Views)
Accepted by topic author Bandit1234
Hi Bandit,
The answer is quite simple: THINK DATAFLOW!
You did not follow that basic LabVIEW mantra, and so the loops will not run in parallel!
This becomes easily visible once you use the AutoCleanup button!
Why do you need two loops at all? Why not place all into just one loop?
(3,098 Views)
(3,093 Views)
Hi Bandit.
your images look different than the block diagram of the attached VI, so you edited it in the mean time!?
(3,087 Views)
I never used auto clean before. Very very useful tool.
I can see the problem with the stop button now.
Thanks very much. Much appreciated.
(3,071 Views)
