Parametrized database query returns different results from hardcoded query on new Windows 10 machines, but not old W7 machines or an old W10 machine.
We have a mature set of software that we've been running on Windows 7 for years. We have a VI, Dusty_Type_Query.vi that queries our MySQL database with
SELECT
FROM
dust_type
WHERE
dust_name LIKE ?;
with parameter "%name%" where name is an optional input if you want to search amongst data with a certain dust_name. In 99% of cases, this optional query is omitted, and the query runs as
SELECT
FROM
dust_type
WHERE
dust_name LIKE "%%";
which returns an array of data, the first element of which is id_dust_type, a value that runs from 0 to 104. Of course, in such a case, the WHERE dust_name LIKE "%%" could be removed and you'd get the same result.
However, we've recently upgraded our machines to Windows 10 (but we continue to run LabVIEW 2015), and while the rest of our software is working, this code has recently started returning strange, incorrect results, but only on these two new machines. It returns the correct array of data as before with one critical exception: all of the id_dust_type data are 0. So, the exact same VI correctly reads a dozen other entries of various data types, but the first column of data is always zero.
I have had this software on my personal windows 10 laptop, also for years, and it works without issue there.
What's truly bizarre is that hardcoding the query to the exact same thing as what it should be results in expected operation. That is, running the VI with hardcoded
SELECT
FROM
dust_type
WHERE
works as expected, outputting the correct data, id_dust_event included.
The VI we have outputs the fully parametrized query, and while this is something one of my colleagues cooked up years ago, running whatever it outputs in MySQL has in the past never returned a different result than the VI itself. That's aside from the fact that just by looking at the code you can see it should replicate the parametrized query as an output.
Losing my mind, I copied the text from this using the working hardcoded method and the not-working parametrized method. I then ran a diff on them to see if something was escaping my eye, but nothing was.
If there were an error, I'd expect something to complain, not to merely output data with wrong values, and in only one of the dozen columns at that.
I also tried running it with dust_name specified to "Iron" which is our most commonly used dust. This didn't change anything. The parametrized query returned all of our iron dust data but with id_dust_event again all incorrectly returned as 0. Hardcoding the query to
WHERE dust_name LIKE "%Iron%";
works as expected, returning the iron data but with correct id_dust_event numbers.
I have never seen anything like this and would very much appreciate it if someone could restore my sanity.
working:
not working:
Param DB Query:
Running LabVIEW 2015 on Windows 10 Enterprise.
LabVIEW 2015 Database Connectivity Toolkit 15.0.196 (this is the same on my personal laptop, where the code works)
(2,982 Views)
You are obviously using the Database Toolkit. While that does some logic on LabVIEW level most of it is delegated to ADO/DAO through the ActiveX interface which then handles the queries either through a ADO driver or via the ADO-ODBC bridge through an ODBC driver.
So my guess is that you are not using the same MySQL driver on the different systems. Either that or there must be a difference in the ADO/DAO layer itself between the computers. Differences in parameterized queries between driver versions is absolutely not something that would surprise me, it's a complicated interface and there are many possible reasons to change behaviour there between versions.
Rolf Kalbermatter  My Blog
(2,918 Views)
I agree with rolfk.  I seem to remember a setting for MySQL driver about using single or double quotes in your queries.
aputman
(2,886 Views)
Howdy folks, thanks much for the hints. I know nothing about ADO/DAO, so I've got some googling to do. I remember there being some options to play with during the MySQL driver installs. But perhaps I can merely begin by selectively updating drivers on my personal machine to see if I can replicate the problem there, as this might tell me which broad thing is causing it.
If that doesn't work I'll start digging deeper into this ADO stuff, as I don't know where to begin with that yet. Will update this thread when I find something.
In any case, an error in another piece of software is resulting from the exact same problem. The first column in that return is also all zeros, only when using a parametrized query.
(2,829 Views)
Actually now that it appears this is not a LabVIEW issue, but an ODBC issue, google is already turning up fruit, such as:
https://stackoverflow.com/questions/58459844/parameterized-query-that-returns-text-columns-always-re...
https://stackoverflow.com/questions/58674295/parameterized-query-with-pyodbc-and-mysql8-returns-0-fo...
This would suggest that I'm posting in the wrong forum, as it's not a LabVIEW issue per se, but I'll nonetheless update when I figure it out for posterity.
(2,827 Views)
Accepted by topic author barriboy
OK folks, thanks for the hints. I think I would have spent another few days blaming LabVIEW for what turned out to be an error in the MySQL ODBC driver.
It seems from this post on stack that this was caused by  MySQL ODBC/Connector bug 91191. Updating to the current driver, 8.0.19, fixed the problem, but it wasn't that simple.
When I attempted to install, it threw up an error that I needed to install Microsoft Visual Studio 2015. Surprised, as I thought I had already done so in installing MySQL to begin with, I went on a wild goose chase trying to download the 2015 version without having to sign up as a Microsoft developer, only to find once I had managed to do so that, after 10 minutes of install, Visual Studio 2015 couldn't install because it already was installed. It then developed that the infinite wisdom of Microsoft was the culprit, and after repairing Visual Studio 2017, rebooting, installing MySQL Connector/ODBC 8.0.19, and rebooting again because why not, all my woes went away.
Computers are fun.
rolk, aputman, thanks again.
Cheers,
Zach
(2,801 Views)
