Parcing data from uC (2)
I am sending this: "b,4.53783,4.10000,00:03:59" (confirmed with a terminal) from a microcontroller and would like to write this to a txt file.
The format should be something like this: 4.53783  4.10000  00:03:59.
What i am actually getting is this: 4.538 4.100 0.000 3.000 59.000.
Any ideas?
thanks
(3,261 Views)
Accepted by gillettestm32
Hi gilette,
when you want to handle strings then you should handle strings (and not numerics!):
More recommendations:
  • use a format string of "%[^,],%f,%f,%s" to scan the received string
  • there are also format codes to scan timestamps…
  • don't use ExpressVIs (like MergeSignal) to handle your data!
  • it's called "to parse" when you analyze text…
(3,250 Views)
@GerdW wrote:
You could just use Search/Replace String to replace all of the commas with tabs.
(3,243 Views)
Hi crossrulz,
you still need to delete that first item in the list/vector/array…
(3,238 Views)
Doh...
thanks a lot
(3,219 Views)
