Parks vector transform
I will discuss with my supervisor about purchase of this modulation kit.
Your attention and consideration is highly apprciated. Thank You
Kind Regards
Muhammad Irfan
0060149087570
Message 11 of 16
(1,467 Views)
I will discuss with my supervisor about the purchase of this modulation kit.
Your attention and consideration is highly appreciated. Thank you
Kind Regards
Muhammad Irfan
Message 12 of 16
(1,465 Views)
Morning,
Thank ou very much for this information, highly valuable.
I do have the MT Downconvert Passband.vi" and "MT IQ to XY Graph.vi" but I am having problems when programing them.
In my case, instead of acquiring and process the signal I am reading signal from a TDMS file.
When I try to run the vi I get these errors:
"The requested sample rate is not high enough for the specified passband bandwidth. Increase the sample rate or decrease the passband bandwidth."
the if I decrease the passband bandwidth I get:
"Failed to design downconversion filter; Try less constraining filter parameters"
The sampling rate I used was 25 kHz, the carrier freq 50 Hz, and I have 30 sec data sets.
I am attaching the vi.
Thank you very much in advance.
Message 13 of 16
(1,437 Views)
Dear Sir
Can you please guide me what is the error in attached two vi which are used to compute Park Transform.
Best Regards
Irfan
Message 14 of 16
(1,376 Views)
Dear Rob_Ward
I have purchase LabVIEW 2012 professional with advanced signal processing tool kit. But still I am unable to find the Park Vector Transform VI. Can you please assist me.
Kind Regards
Irfan
Message 15 of 16
(1,367 Views)
Dear Sir
Can you please guide me to compute Park Transform.
Best Regards
Irfan
Message 16 of 16
(1,361 Views)
