Parsing HTML - RegExp
HI!
I have a problem with parsing some HTML code (table). I'm not too good with regular expression and I need help.
The HTML code is in vi. How to get marked ones in array using regexp?
Ty!
(3,454 Views)
Accepted by SecondBatman
There are hundreds of expressions that will match a result...
Something like this: "(?m)<td>\s*([0-9]+\.[0-9]+)". Then use the first capturing group.
No expression will give an array. You'd have to loop until the index is -1. Put the index in a shift register, and use it for the next iteration. Don't add the last element, or delete it.
EDIT: Use "(?m)<td>\s*([0-9]+\.?[0-9]*)". Or (?m)<td>\s*(\d[^<\s]+)
(3,451 Views)
That was it, thank you. I guess I shoud improve my regexp skill 😐
(3,418 Views)
If you throw that expression into a RegEx editor, like RegEx101.com, it'll explain just exactly what that expression is doing.
(3,412 Views)
Simple cases like this are fine, but due to some unfortunate choices in the LV Regex function I often resort to Search and Replace to do the opposite job:  instead of pulling out what you want in a loop, replace everything you don't want with an empty string.
(3,399 Views)
