Passing output value through for loop
Hi Diane,
I suggest that You take a look at the detailed account that Bob_Schor gave you.  He explained pretty well how to use the producer consumer loop to read the values in the producer loop and then the consumer loop will run off of those messages.
If you don't understand it or it doesn't fit your needs can you explain exactly why it doesn't?
Pat
Message 11 of 13
(1,239 Views)
Hi Bob, What's the icon with the eraser, with the note next to it which says 4=EOF?
Message 12 of 13
(1,211 Views)
Clear Errors.
Message 13 of 13
(1,205 Views)
