11-17-2011 03:10 AM
Hello, I've two questions:
I would like to know what sort of variable types can I pass into labview from C# or python, using activeX.
I guess they would be things like, number types, strings, etc. But what about paths, or error clusters?
Also in labview I normally pass in objects into my subvi's (since I use OOP). How would it be possible to do this from another language?
Lets say I have a self defined database object that I normally pass around in labview. Can I call some factory method vi from C#, and get the control from the front panel after running the vi. Cast that as a generic object in C#, and then call another vi, and pass in the object?
Like.
// Get a vi reference, and run my databaseFactory vi.
string databaseFactoryPath = ...;
VirtualInstrument databaseFactoryVi = labVIEWApp.GetVIReference(databaseFactoryPath "", false, 0);
databaseFactoryVi.Run(true);
// Get the database labview object from the frontpanel control called "database out"
object databaseObject = (object)viTest.GetControlValue("database out");
// Obtain a reference to a database method called load.vi
string databaseLoadPath = ...;
VirtualInstrument databaseload = labVIEWApp.GetVIReference(databaseFactoryPath "", false, 0);
string parameterName = "database in";
databaseLoad.Call( parameterName, databaseObject );
Will that work?
labjunky
11-17-2011 03:44 AM - edited 11-17-2011 03:46 AM
Well my example above doesn't work 😞
I get an exception thrown on the line:
"The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
the databaseObject comes back 'null"
Anyone know how to do this type of thing properly?
thanks,
labJunky
