Pausing a VI and getting results
I would like to run a VI. At the moment of running that VI i need to get the exact real time from the computer, RT (begin). I also give a time interval T(int)= 2 minutes. I want to check all the time ( at the time during the VI is running) whether the real time of the computer RT(present )  = RT(begin)+T(int).
If it is true then i need to stop the vi. How is this possible.? I tried to get the time from the computer, but it is in string format and it is not possible to add or subtract and check the condition. I also tried with a  Tick count function  but its not wrking. Any ideas.. see the attachment
Nghtcwrlr
(2,975 Views)
Hi Nghtcrwlr
Here's an example
Best Regards
David
NISW
(2,947 Views)
Hi David
Could you please save the vi in LabVIEW7.1 Version. ?
Thanks.
Nghtcwrlr
(2,935 Views)
Accepted by Nghtcrwlr
Here you go
/David
(2,920 Views)
