Phase Shift and Power Spectrum..
I am implementing a Lock-in amplifier.. the signal tht i am talking abt comes from the multiplier which does the analog multiplication of the input signal and the reference signal.. so when i pass tht into the amplitude spectrum and then use the extract signal vi, i can specify that i need only the value at point - '0'.. and thus i can take tht value as the reading right.. suppose if i use the filter-rolling average method, i am quite confused abt choosing the correct type of filter (how do we decide tht) and also the implementation of rolling-average.. can u just gimme me a link tht explains rolling-average and also tell me a how is it useful in this case...
thnx..
gokul.
Message 21 of 25
(1,678 Views)
some one plz help me...
Message 22 of 25
(1,665 Views)
plz.. help me... plz..
Message 23 of 25
(1,656 Views)
Try searching the forums for your question!
Rolling Average
http://forums.ni.com/ni/board/message?board.id=170&message.id=165594&query.id=103851#M165594
Some of the people answering your previsous questions have helped in this thread...
Message 24 of 25
(1,650 Views)
Hi Gokul,
Probably the easiest way to measure the DC value of a sampled signal is to use the "AC & DC Estimator (Not in Base Package)" VI, which is found in the Analyse>Signal Processing>Time Domain functions palette.
The function also estimates the "total AC (RMS)" value of the signal.
Try to ensure that you sample several cycles at least (ideally 6 or 7 or more) of any periodic frequency content to minimise measurement/separation error.
Mark H.
Message 25 of 25
(1,643 Views)
