Plot error bars
I have found the NI webpage "Plotting Error Bars in LabVIEW ("Stick Plots") which gives an example of how to plot the Y error bars.  This example works fine for plotting the Y errors and I have modified it so that it will also plot the x errors as well (see attached gif-picA).
Because an error bar is just a single graph with X(or Y) constant, when I plot the data with the error bars the error bars are each plotted to be different colors.  While this looks pretty, I need to have all the error bars to be the same color.  To fix this I progmatically change each plots color using a property node (see atteched gif-picB).  This seems to work for small data sets but the problem is if I have a lot of data points it takes several minutes to change all the error plots colors.  I need a quicker/better solution.  It is possibble that I could have data sets as big as 10000 or more.
Does anyone have any suggests/ideas that I could try to speed this up?  Is there a better way of plotting error bars?
Thanks!
G
ref:
[link removed; example no longer available]
(5,075 Views)
Try the Min Max plot, but you have to reshape your data.
(5,054 Views)
Hi unclebump,
Thanks for the reply.
I took a look at the Min Max plot example that you suggested but it doesn't quite help with the X error bars.  Also try changing the constant for the number of iterations on the first for loop from100 to 10000 - It caused LabVIEW to crash with a "not enough memory error".
The problem is that the errorbar.vi creates stick plots for each data point so for a data set of 10000 points it creates 30000 individual plots (10000 for data points, 10000 for Y error bars and 10000 for the x error bars).
Any other suggestions?
(5,045 Views)
Sounds like a case for an activex excel line chart with error bars added to it.
(5,034 Views)
If you use LabVIEW 8.20, you can find function errorbar in MathScript. Try it!
(5,025 Views)
I found this on LAVA.
also these.
http://zone.ni.com/devzone/cda/tut/p/id/3190
http://zone.ni.com/reference/en-XX/help/371361B-01/lvtextmath/msfunc_errorbar/
http://ssf.ugent.be/linac/linac/graph_with_error_bars.htm
(5,009 Views)
Thanks unclebump,
The XYGraphErrorBars example that you provided was exactly what I was looking for.
Thanks again for your quick responses!
G
(4,993 Views)
