Popup for resoure location when build for installer
When I build the installer, it popup the request for LV8.2.1 install location.
I put LV8.2.0 CD and the driver CDs in, all cannot work.
Any suggestion?
(2,881 Views)
Hi Turbot,
Can you make sure you have the LabVIEW 8.2.1 Run Time Engine at: C:\Program Files\National Instruments\Shared\ProductCache\NI LabVIEW Rutime Engine [8.2.1]?
If not, you can download at:https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html
I suspects the error occurred because missing LabVIEW 8.2.1 Run Time Engine. Kindly let me know if it solve your problem, thank you.
Sincerely,
Krisna Wisnu
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
(2,856 Views)
I have checked. The LV8.2.1 runtime engine is there as attached screen shot.
Any other suggestion? Thanks
(2,854 Views)
Accepted by topic author alex.
Hi Turbot,
I tried a little bit of searching through the forum. Please browse through the forum below and see whether you can solve the problem by the solution provided or not:
 https://forums.ni.com/t5/Machine-Vision/why-it-keeps-on-asking-quot-NI-LabVIEW-8-5-1-quot-distributi...
 https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/quot-Distribution-Not-Found-quot-error-when-...
You can refer to this KB:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OIGSA2&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MpDSAU&l=en-US
Let me know if the article solved your problem or not.
Sincerely,
Krisna Wisnu
(2,845 Views)
