 alex.
			alex.
			11-27-2008 01:20 AM
When I build the installer, it popup the request for LV8.2.1 install location.
I put LV8.2.0 CD and the driver CDs in, all cannot work.
Any suggestion?
Solved! Go to Solution.
 KrisnaWisnu
			KrisnaWisnu
		11-27-2008
		07:35 PM
 - last edited on
		05-17-2024
		02:06 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Turbot,
Can you make sure you have the LabVIEW 8.2.1 Run Time Engine at: C:\Program Files\National Instruments\Shared\ProductCache\NI LabVIEW Rutime Engine [8.2.1]?
If not, you can download at:https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html
I suspects the error occurred because missing LabVIEW 8.2.1 Run Time Engine. Kindly let me know if it solve your problem, thank you.
Sincerely,
Krisna Wisnu
11-27-2008 08:01 PM
I have checked. The LV8.2.1 runtime engine is there as attached screen shot.
Any other suggestion? Thanks
 KrisnaWisnu
			KrisnaWisnu
		11-28-2008
		12:31 AM
 - last edited on
		05-17-2024
		02:07 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Turbot,
I tried a little bit of searching through the forum. Please browse through the forum below and see whether you can solve the problem by the solution provided or not:
You can refer to this KB:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OIGSA2&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MpDSAU&l=en-US
Let me know if the article solved your problem or not.
Sincerely,
Krisna Wisnu
