‎12-05-2012 11:36 AM - edited ‎12-05-2012 11:37 AM
I'm working on getting everything setup to use a source control program (Git) with LabVIEW. So far I've had success using appropiate tools for merging vi, ctl, lvproj, lvclass, lvlib, seq extensions. I'm a little bit confused over the llb extension.
If I manually call the Tools/Merge/Merge LLB... from the menu, it pulls up a nice UI and I can walk through the llb and determine each vi that was changed and merge appropitately. However, when I read the help file on doing it by command prompt. it states: "You also can configure a third-party source control provider to use LVMerge.exe as the default merge application. LVMerge.exe is equivalent to the Select LLBs to Merge dialog box." Source. When I attempt to call that. It generates an error code 7, NI_FileType.lvlib:Get File Type.vi.
So the question comes, is this a bug in documentation, or a bug in code. And what work around is there so I can call the true merge llb by command prompt?
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
‎12-06-2012 01:03 PM
bump bump. Anyone know of a way to call a llb-merge via command line?
‎12-07-2012 10:38 AM
You can check some information about LVMerge.exe at the following link:
http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/configmerge_thirdparty/
‎04-16-2020 09:35 AM
Hi did you find a solution? I feel like a fool not finding the right solution.
‎04-16-2020 10:55 AM
What happens if you simply pass the path to the VIs? Omitting the library. The VI knows it is owned by the library, and I somewhat expect it to find it's library when loaded on it's own (by the LVMerge).
‎04-17-2020 10:42 AM - edited ‎04-17-2020 10:42 AM
Hi wiebe@CARYA,
actually i want to merge VIs, so my point is maybe a lite different, I tried to call LVMerge directly as well as from within my SourcetTee but I cant get it open. it allays ends with an error 7 file not found.
I'm passing absolute paths that are proven to be valid.
‎04-17-2020 10:54 AM - edited ‎04-17-2020 11:08 AM
@M.R.S. wrote:
Hi wiebe@CARYA,
Are the paths quoted? That is required if there are spaces in the paths. In general, when using the command line, not just or specificly for LVMerge.
EDIT double quoted: LVMerge "c:\my vi 1.vi" "c:\my vi 2.vi"
