Prevas Gigabit Ethernet
I have NI PXIe 7966R FlexRIO and Prevas Gigabit Ethernet Adapter. I need to do ethernet analysis using these two. I know LabVIEW and LabVIEW FPGA, but dont know how to access ethernet data from the Prevas adapter.Are there any API or FPGA IPs available to do it. Or some example LabVIEW programs that will help me get started.
(2,551 Views)
The FlexRIO adapter module you are talking about is a third party adapter module provided by Prevas. I would recommend you to visit http://www.prevas.com/ethernet_simulator_mimas.html
You can contact Prevas support and they will be able to provide you required code.
Hardik Asawa
(2,518 Views)
