Previously operational systems are now hanging the PC
Thanks for everyones help and comments - I've found a system register that's corrupted and causing an infinite program loop (incomplete program debugging I think). I've had to remove and re-install Labview to reset this register and I'm now looking at sorting this program error to prevent a recurrance. Thanks again to all for the pointers.
Message 11 of 13
(490 Views)
I do not remeber who it is on Info-LabVIEW, but the signature reads something like;
"There is nothing fool proof for a clever fool".
Thanks for the update,
Ben
Message 12 of 13
(490 Views)
Quoting el-d:
"The initial test screen calls for a serial number and user ID and has several 'Pass/Fail' stages which must be green before the test completes"
That sounds more like TestStand.
Hanging up? Does it ask to do a cleanup? Or some sort of error message?
Re-installing LabView may not be the first step...
I doubt that operator would have done that much damage...
;O)
JLV
Message 13 of 13
(644 Views)
