Print a document with labview
hello, i have a question...
i've just installed LV2013 (on windows7) and i'm trying to learn .net and activeX VIs
i would make a program to print a pdf file...i would that the windows print window appears pushing a button (where i could change printer, settings, etc)
is it possible?
(7,636 Views)
Configuring and selection of printer possible. Check below posts.
https://decibel.ni.com/content/docs/DOC-14719
https://decibel.ni.com/content/docs/DOC-4664
(7,627 Views)
this might help you as well.
http://digital.ni.com/public.nsf/allkb/80DD23A28BD8ADF9862575AC0077B1BB?OpenDocument
Regards.
(7,589 Views)
i have read that page...but i can't find Assembly System.Windows.Forms(2.0.0.0).
(7,556 Views)
1) Put a .Net constructor node on your block diagram
2) Select the constructor
3)  Add an invoke node
(7,532 Views)
