03-25-2010 08:11 AM - edited 03-25-2010 08:12 AM
Maybe i didnt understand what you said james, but i don't want to loose the time data :s. Just display a correct relative time.
03-25-2010 08:55 AM
My misunderstanding Madje,
Try this. I haven't tested it, but you should get the idea.
You can change the data that you put in the queue and change the waveform properties.
The display should not slow down your "data get" here.
James
(Saved for 8.2)
03-25-2010 09:18 AM
Thanks James, but... I still have the problem. Plus i don't really understand what you have done.
Maybe i wasn't clear enough in my explanations. Here's a picture, showing my problem.
03-25-2010 10:22 AM
My mistake, I sent you a broken VI.
Here is a working one which should do the job for you.
Look at the templates to see what is going on.
File>New>From Template
James
