Problem in implementing Logic
I have a sorted array as input and output as I needed.  I need output as each element in array how much time repeated. Attached image for reference.
I tried but didnt get what I needed. Attached VI.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 14
(5,046 Views)
Are you sure you will always have only the Alphabets in the input array?
Message 2 of 14
(5,029 Views)
This is little bit rubed but will help you to sort the array and count the character.
Message 3 of 14
(5,014 Views)
No that will actually that will be string as each member of array
--Ranjeet
Message 4 of 14
(4,993 Views)
Can you please upload in v11
--Ranjeet
Message 5 of 14
(4,992 Views)
Accepted by Ranjeet_Singh
here's a one loop version:
(No need to use three FOR loops…)
@Ranjeet:
In LV2011 you need to replace the conditional output tunnel by a case structure and a BuildArray inside the TRUE case combined with a shift register. See how far you get…
Message 6 of 14
(4,982 Views)
Whats this?
--Ranjeet
Message 7 of 14
(4,974 Views)
That is conditional build terminal available in 2013.
Message 8 of 14
(4,967 Views)
How can I implement in 2011
--Ranjeet
Message 9 of 14
(4,957 Views)
Hi Ranjeet,
as said before:
You need a shift register, a case structure and a BuildArray inside the TRUE case.
Ever tried to use the example finder in LabVIEW and to study the example VIs coming with LabVIEW?
Message 10 of 14
(4,951 Views)
