Problem in segregating the data from array
Dear all,
I am getting the data from different analog and digital channel and continuously storing it in the array.
I want to segregate channel wise data. Please refer attached image.
First three are analog then rest two are boolean then repeat.
can I separate the yellow data in some register, where next value can overwrite the previous one.. and so on for rest of the data.
Please find attachment
Thanks in advance 🙂
(4,267 Views)
Use Reshape Array to turn it into a 2D array so that each row contains a set of readings.  Then you can just use Index Array to get the column(s) you care about.
(4,241 Views)
Accepted by suyash.barodiya
Decimate array, extended to a total of 5 elements, will have the yellow data in the first output and the red data in the second output.
I don't know if this is faster than reshape followed by index. Do a benchmark and let us know!
CLA - Kudos is how we show our appreciation for comments that helped us!
(4,214 Views)
Hi suyash,
after going through some basic LabVIEW lessons you should be able to get to the very basic "index array elements in a loop approach":
(ReshapeArray and DecimateArray will also solve your problem, probably in a more optimized way. But still then you should understand the code you are writing…)
(4,202 Views)
From a scalability perspective, the reshape is better.  The Decimate 1D Array forces you to a set number of channels at compile time.  The Reshape Array allows me to define how many channels at runtime (more scalable).
However, if I had to guess I would say the Decimate 1D Array would likely be faster.  Need benchmarks to prove it.  I may be surprised.
(4,195 Views)
Hello Every one,
Thank you very much for providing me the solution.
All the options are working but decimate array worked for me. I do not have waste knowledge of LabVIEW but in may case i have seen that option of reshaping array is faster than decimate array, but still we need some experts review on it.
Have a great day Smiley Happy
(4,161 Views)
