Problem realtime engine (RTE 2009) on Xp compact panel PC
Peter S,
I was not "fair" but it showed me that the resolution is not the problem here....
There is nothing I can test at this moment. The next step we want to take is to borrow this device for a time and do more investigation on this...
I have to initiate this, but I will be out of the office for a two weeks China trip starting next week.
Thanks for your support!
John
Message 11 of 13
(790 Views)
Hi
You may use command line options to create a log file. If you use the run option in windows it may look like this.
"C😕installer\Volume\setup.exe" /l*v c😕Package.log
This will create a log in c😕 named package.log. You can use the logfile to track the error. NI products for windows use a MSI based installer. You can find out more about the command line options here
http://msdn.microsoft.com/en-us/library/aa367988(VS.85).aspx
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 13
(782 Views)
Thanks Coq Rouge,
The supplier of the PDX-057T has already promesed me to supply me a testunit....
This will be continued in week 43..
I will use your loggin proposal to track the behavior of this device.
John
Message 13 of 13
(778 Views)
