Problem with cluster elements sum
Hi
I have a problem (perhaps very simple to solve). I have a cluster with 3 integers inside. I`m building an array of these elements (after unbundling my cluster) and I want to sum all these elements. However, my result is not satisfying. For example: my array: [255,255,238] and LV shows me sum of these elements: 236.
Probe 6 on my printscreen: my array
Probe 7: result of sum operation
What am I doing wrong? Thanks in advance
(3,269 Views)
Accepted by e-nDrju
Your datatype seems to be U8, so the maximum value can only be 255. (It is a bit hard to read because of the image scaling). Why don't you attach the VI instead?
If you need the real sum, you need to convert to a different representation (e.g. U16) first.
Also, what is the purpose of the FOR loop? Since it only runs for one iteration, you might as well delete it.
(3,266 Views)
How didn`t I notice that ? 🙂 Thanks a lot - I knew it was stupid.
And about that loop - it will be more than 1 iteration (number of snapshots taken by cam and saved to bitmap file), but I`ve changed it for a while for easier debugging.
Thanks once again.
(3,257 Views)
