Problem with pin reference (USB 6218)
Hi evryone,
I am confused concerning the pin references for USB-6218. MAX says to use  pin 15 and 16  for a differential AI (AI0/AIground) on the first channel. This seems correct because my measure looks ok. But when I look at the data sheet (http://www.ni.com/pdf/manuals/372085b.pdf)  these pins correspond to PFI 6/P1.2 and D ground.  The AOs don't match either.
I must be making a mistake when reading the data sheet. Would anybody know what I am doing wrong?
User
(4,584 Views)
You have miss interperated what "Differential" means
Max is telling you to use AI0+(P15) and AI8+(P16) to create a task that reads the voltage differeance between those two nodes (A differential measurement)
A non referanced single ended measurement (NRSE or Pseudo differential) would use AI0(p15) and AISN(p23)
A Referanced Single Ended (RSE) would use AI0(p15 and AIGND(p28)
PFI 6/P1.2 and D ground are on pins 8 and 5.
(4,569 Views)
Thanks for your answer. I am sorry but I still don't understand how to read correctly the data sheet.
For instance, how do you get  to your conclusion "PFI 6/P1.2 and D ground are on pins 8 and 5" using the datat sheet I have send? Don't they correspond to pin 15 and 16 according to data sheet?
User
(4,555 Views)
I have just realised I hadn't attached the correct data sheet (the one I wanted to disccuss I mean) in my first email.
All my questions and comments relate to his one https://www.ni.com/docs/en-US/bundle/usb-621x-oem-features/resource/372083c.pdf       (page 6)
(4,553 Views)
Hi User_1979,
Did you use a simulate device in MAX?
These Connections refers to this datasheet of the USB 6218 (P.15). Your measurement seems ok between pin 15-16 (AI0-8), the behaviour is normal.
Also you can find the device pinout within MAX by right click on the device and click to view the pinout.
(4,533 Views)
Accepted by User_1979
You say you are using the USB 6218 but then you post the manual for the USB 6218 OEM. Which are you actually using?
(4,531 Views)
Hi Remi and Dennis,
You were right Dennis, I hadn't noticed this data sheet was for the OEM version.... When looking at the correct one I get the same information as what I get with MAX and what I have seen with my measures.
Thanks a lot,
User
(4,515 Views)
