Showing results forĀ
Search instead forĀ
Did you mean:Ā
Program to sort the outputs
How to make a Labview program so that, the successive outputs should be sorted in two separate columns. For example, if I have a program named "Read", for each run of "Read", it will give an output. I wan to run it, say, 200 times. I want to put the successive outputs in two columns P and Q. The output of the first run in column P, 2nd run in column Q, 3rd again in coumn P (second row), 4th in colum Q (second row), 5th in column P(third row), 6th in column Q(third row) so and so...... How can I make this loop?
Better if I can use a for loop! but confusing how to separate into two columns...
I am new in Labview. It would be great if someone can give me a sample program to illustrate this. Thanks a lot...
(3,346 Views)
I would use a FOR loop with 2 calls of your subVI in it.  You can then combine the results into an array (Build Array) and use Autoindexing to come out with a 2D array.
(3,328 Views)
You can also run your program in a loop and index the output into a 1D array and then use Decimate 1D Array.vi (in the Array Palette) to split it into two arrays that contain alternating values from the original array.
(3,309 Views)
@NIquist wrote:
You can also run your program in a loop and index the output into a 1D array and then...
That's a good idea.  If the OP wants a 2D array, I would use the Reshape Array function.  Then you can turn it into however many columns you want.  A lot more extensible than my original idea.
(3,299 Views)
decimate, build (do not concat) and transpose
Those functions on the array manipulation palatte can be fairly helpful.  A quick look through the help is in order.
Spoiler
Now wait for altenbach to do this on a postage stamp using CDB data
(3,294 Views)
Or, if you need to scale it up to an arbitrary number of columns the Signal operations palatte has a real gem.
(3,284 Views)
Or you could just use Reshape Array...
(3,275 Views)
