Programmability resize string indicator
Is there a way to programmatically resize a string indicator so that it automatically resizes to the data "coming into it"?  I created a simple subvi that displays data to the user and ( modified) the busy indicator shipping example.  This is so I can use this generic vi through out my entire test and not create dozens of vis w hard coded messages.  The messages are different in length and I don't want to create one large display and have blank spaces shown when a smaller message is needed.  Thought about setting the size property node but that would mean passing the size of the current indicator message width/height to the subvi..Didn't know if this would work because the subvis font is larger and bold.  To me it seems like there should be a way for the subvi string indicator to "know" how much space it needs to properly set what string it contains.
Thanks..
(5,094 Views)
Accepted by clint100
Hi clint100,
did you look at VI "Size To Text for string control" (can be found in your folder ...\labview\examples\general\strings.llb) ? If I understood your problem right I think it could help you...
Eduard Gross
(5,076 Views)
Thanks Eduard,
I was using a property node when I should have been using a method.
(5,044 Views)
