Programmatically Control the PC audio card volume and sample rate instead of application's volume and sample rate
Hi all
      Can somebody help me to figure out how I can set the volume and sample rate of the audio device instead of the applications.
     I try to call winmm.dll but I can only set the application's volume and sample rate.
Thanks and Regards
诸位大神:
谁能教我一个用VI 控制声卡音量和采样率的办法,而不是控制应用程序的音量,我调用winmm.dll也只能配置应用程序的音频信息。
谢谢了。
set audio device volume instead of APPsset audio device volume instead of APPscall winmm.dllcall winmm.dll
(3,167 Views)
Hello All,
Is there a solution for this?  Even if the PC volume can be set that would be great.
(1,957 Views)
