Programmatically getting MAX devices and interfaces info
How can I programmically get all available info from Devices and Interfaces of MAX using LV?
I already tried this: http://digital.ni.com/public.nsf/allkb/8532AFF2C7E14F5E86256FEA003E202F
It works for NI instruments. But only for NI.
BR,
Jick
Message 1 of 15
(7,357 Views)
Hi Jick,
using DAQmx functions (or property nodes) you can get information on all available DAQmx devices (real or simulated).
To get information on other devices (like GPIB, COM port, etc.) you have to use VISA functions like this one...
Message 2 of 15
(7,353 Views)
Thanks GerdW,
Next problem is that VISA Find Resource.vi finds devices which have been installed and present earlier but are not currently present. Is there a way to find out if a device is currently present or should I just do a VISA query individually for all devices found to ensure presence?
BR,
Jick
Message 3 of 15
(7,348 Views)
Hi Jick,
VISA finds all possible ports (like COMx) even when there is no device connected. Yes, you should query each found port...
Message 4 of 15
(7,345 Views)
Can you upload your find VISA resource VI in 2011.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 5 of 15
(7,335 Views)
Why?
Br,
Jick
Message 6 of 15
(7,333 Views)
Becasue what I have doesn't show other when not avaiable.
--Ranjeet
Message 7 of 15
(7,317 Views)
Hi Ranjeet,
then why don't you show your VI?
Message 8 of 15
(7,309 Views)
I could be wrong but for my app, com port comes occasionaly when USB module is connected. Hence in my case it works reliabely.
--Ranjeet
Message 9 of 15
(7,306 Views)
I would suggest using NI System Configuration. It should return information for anything that shows up in MAX and it exposes an "Is Present" attribute if you need to detect if something is currently connected.
It includes a LV shipping example called Show All Hardware that you can use as a starting point and you can also use NI System Configuration to rename, self-test, self-calibrate, and reset devices just like you can from MAX.
Message 10 of 15
(7,282 Views)
