‎02-03-2017 02:30 PM
I need help with programming a temperature ramp for the hot plate from Torrey pines HP60. Would I be able to just connect it to the hot plate and run the program on the computer?
I do not have a program to run at the moment and am new to Labview.
I watched the Labview tutorials but still not sure where to begin. I tried to look up for example program but am unable to find any.
‎02-03-2017 02:54 PM - edited ‎02-03-2017 02:54 PM
How are you communicating to the hot plate? Is it a communications bus (RS-232) or an output from a data acquisition device (analog, discrete)?
‎02-03-2017 03:28 PM - edited ‎02-03-2017 03:34 PM
It's possible to use a USB serial cable and connect it between the hot plate and the computer. Would I be able to just write a program thorugh that connection only or do I need an output from a data acquisition device?
‎02-03-2017 04:41 PM
You should be able to control the hot plate through the RS-232 connection. See if the manufacturer has LabVIEW drivers and examples for controlling it. This will save you a lot of time. The manual should also describe the communications protocol over RS-232.
‎02-03-2017 04:50 PM
I tried to look up for LabVIEW examples too on their site but wasn't able to find any. I'll look at the manual again.
Thanks!
