Project advice and help
Hi all,
I am going to start on my project for my master program. I was wondering if anyone can help me?
i  need to know what I can use that is low cost.
I will be using labview 8.0. I need to communicate with a hardware of anytype.
what i have in mind is probably a camera, video or something. or even a tv screen/dvd player.
the idea i have is to read those videos into labview and do some type of compresssion or something.
i dont know where to start. dont know what pci to use. does anyone have an idea?
please help me..
thank you in advance
Krispiekream
(3,400 Views)
Hi there
I'm not sure what to advise as your description seems a little vague.
You say you would like to read signals into labVIEW. This sounds great, you can do loads of great stuff in labVIEW with Vision though I would ask do you have the vision toolkits for labVIEW 8.0 or Vision Assistant,  Vision Builder?
Hardware - you would like to communicate with hardware of any type?      TVs etc are passive so these yyou cannot easily communicate with image-wise. I think a camara is your best bet though again the method of receiving your signal is somewhat imaterial for this you could just use a saved vidio file. How exactly do you want to compress it?
If you can give me slightly more clarity then I will try and advise.
best regards
Message Edited by GrahamG on 11-29-2007 05:44 AM
Graham Green
Software Product Marketing
NI | Emerson
(3,377 Views)
the teacher basically let me choose my own project. i dont know what i want to do.
i dont want to spend so much money because its out of my own pocket.
i have labivew 8.0 from work and i have downloaded vision assistant trial edition.
i want to use AVR microcontrollers? i dont know what i want to do with it. but thats what my professor suggested.
what can i do with labview and AVR?
if i use labview vision with a TV for instant. can i stream tv quality into labview program?
Krispiekream
(3,353 Views)
why don't you try something more simple. A SCADA system perhaps.
AVR will get the data .. Labview will display
(3,326 Views)
I'm not confident what I can recommend to you,  AVR microcontrollers are quite a wide area. LabVIEW as a language can be used again for a huge variety of applications.
I think as this is your masters project only you can decide on the Idea or concept you are going to research into. If at a later stage you have problems or need advice with the implementation of this then I would be most willing to assist.
Good luck with your research and I look forward to being involved as your project progresses.
Best regards
Graham Green
NI | Emerson
(3,315 Views)
