Prompt user for invalid data
@aniketjha wrote:
... not necessarily it should be 32 bit length but max 32 bit length.
That makes no sense. Are you talking about 32 characters? That's an awfully long serial number. 😄
Message 31 of 42
(2,833 Views)
Yes Altenbach, this is the requirement 😊
Message 32 of 42
(2,828 Views)
We have a very long thread with many messages. What is "this"?
Message 33 of 42
(2,825 Views)
Ok, Crossrulz i will try to implement, and post if  i have further doubts.
Aniket
Message 34 of 42
(2,823 Views)
"This" means the serial number and it's length.
Message 35 of 42
(2,820 Views)
Scanned through the thread, only one thing to add:
"Who's on first?"
-Kevin P
Message 36 of 42
(2,813 Views)
At various times the length has been quoted here as 32bits, 8 characters, 4 bytes, 32 characters and many other variations. If it is just max 8 printable characters, use the code I linked earlier and change one diagram constant.
Please write an entire paragraph explaining your definition of "serial number", including:
  • min and max string length (e.g. empty string is not a valid SN)
  • Allowed characters (number, uppercase, lower case, special (e.g. %), etc.)
  • Valid patters (e.g. "4 numbers-4 letters")
  • Are some characters always the same?
  • Valid numeric range if scanned.
  • Need to match a certain regex?
  • What is the final datatype of the validated serial number output going to the caller code?
  • etc.
Then make a list of at least 10 valid serial number and a list of 10 similar, but invalid serial numbers so we can get a better idea.
The "I know it when I see it" method does not work in computing.
Message 37 of 42
(2,811 Views)
And, we are right back to my Regex and key filtering fSmiley Very Happy
Some days the irony amazes me.  "Prompt User for invalid Data"  Sounds like the OP has that down pat!
Message 38 of 42
(2,807 Views)
Yes, we are going in circles. I won't contribute more unless all my questions above are answered in detail.
Message 39 of 42
(2,797 Views)
@Kevin_Price wrote:
"Who's on first?"
I don't know...third base!
Message 40 of 42
(2,790 Views)
