Property Nodes Labview NXG
Ok so I started playing with labview nxg looking at the properties for specific controls and indicators a lot of them are missing. E.g. The property "plot.name" for a waveform graph, but its missing in NXG, is this something that will be added in the future or am I looking for it in the wrong place?
Thanks.
Message 1 of 8
(7,197 Views)
Accepted by OA1
You likely are looking in the right place.  NI has said they are prioritizing properties and methods of UI controls, and implementing the functions people use the most.  This will likely mean feature parity with LabVIEW 2017 won't be for a while.  If you notice that a missing property or method means you can't port an application to NXG, be sure and bug NI in the hopes it will move up their priority list.
Also property nodes don't exist at all for WebVIs in NXG yet.  So something as simple as hiding a control isn't supported without various work arounds yet.
Message 2 of 8
(7,151 Views)
This implies that NI felt that LabVIEW developers rarely used the CAPTION property???
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(7,145 Views)
@billko wrote:
@Hooovahh
I can't say that.  I can say one of two things.  Either NI saw that other properties like Visible, and Disable were used much more often than Caption and therefore needed to be prioritized, with Caption coming later (so caption isn't rare just less common)...or NI made a decision to not support Caption and wanted to go in another direction giving similar functionality in another way that may or may not be in NXG today.  Both honestly suck a bit for migrating to NXG today.
Message 4 of 8
(7,137 Views)
Seriously annoying that they've done this, because there are some really good features in NXG
Message 5 of 8
(7,112 Views)
Accepted by OA1
While properties in WebVI are generally missing right now the property "plot.name" exists already for GVI's:
Message 6 of 8
(7,102 Views)
Great stuff, but there are missing properties, correct? Is there a list of all properties within NXG as of now?
Thanks.
Message 7 of 8
(7,097 Views)
I dont think there is a list as of now and there are a lot of properties missing right now. For example you cannot set the upper or lower limits for x- and y-axis (not to be confused with the scale) programmatically, which would be great..
Message 8 of 8
(7,088 Views)
