Property node - setting custom time?
Ben, Ravens and myself have showen you several aspects of the path. This is your task to follow it 🙂
As Ben clearly said, it would be a spoiler to do it for you.
i see you brought back your vi to original: the first problem you solved is now again there. look carefully at what you want to write to the output cluster, versus what you actually write.
Then figure out how to define the begining of the chart for all waveforms, using the solution either Ravens or me have proposed.
good luck and please post on your results!
... And here's where I keep assorted lengths of wires...
Message 21 of 23
(887 Views)
thnx I solved it 😉
Message 22 of 23
(876 Views)
i have fixed it thnx
Message 23 of 23
(875 Views)
